I'm just wondering if anyone here ran these tires...
Tread life...off-road, road noise, wet, etc.
I have a set of 35"'s. 7600 miles on them so far with no complaints. I have rotated them twice and had them balanced on a Hunter machine and my wear pattern is pretty close to perfectly even. I run between 25-27psi and check for uneven treadwear once every coupla weeks. They are also pretty grippy. Compared to BFG MT's it is downright sticky! I run curves at speed and never fell slip. Pretty good in rain too. The only real downsides are these:04RedLobster said:I'm just wondering if anyone here ran these tires...
Yeah you are going to always find some mixed reviews on all tires, in the end you have to go with what you will feel is best. A lot of people have been saying the Trxus M/T tread life is short, they are impossible to balance, and tread seperation is common. None of which has happened, nor do I believe are going to happen to my set (currently approaching 10,000 miles).04RedLobster said:yeah i saw them on tirerack.com
the only negative feedbacks was from owners of like F-250s....
yup, I will update my site inna day or 2Andrew123654 said:Nice taco Boheefus, Iv got the same set-up but with 285-75-16's. Iv got alot of space between the tires and fender so Im going to try and step up to some 35's next time around. Got any more pics?
Toyo4x4 said:A lot of people have been saying the Trxus M/T tread life is short, they are impossible to balance, and tread seperation is common. None of which has happened, nor do I believe are going to happen to my set (currently approaching 10,000 miles).
had a buddy w/ em' on his Z71, they weren't bad as far as road noise, but they are a mud tire, keep that in mind. Wet, hmmm, not so bad. However, don't let em' get cupped, they'll ride like shit!04RedLobster said:I'm just wondering if anyone here ran these tires...
I guess we will see, but they've been unstoppable so far. Outperforms my friends BFG in the snow. How often did you rotate?03trdblack said:My TrXus tread didn't seperate until around 11-12,000 miles. I would hope that you don't have that problem, but I feel you will eventually. And yes, they will become impossible to balace correctly after a while...mark my words.
What is Siping ?colorado125 said:I was wondering, has anyone had experience siping the Dunlop Muds? If so, like or dislike? Inner lugs only? etc. Anything.
