Ok, so I take the truck down to the dyno shop to get baseline numbers before I put the blower on. After each pull, the truck would shut off, I could restart it, but it would just spool back down and die. I could keep it running by playing with the thottle and it sounded fine but as soon as I tried to let it idle...it would die. If I unhooked the battery for a couple seconds and tried again...no problem. I've dynoed several different vehicles and never ran into this. No check engine light either. Any ideas????
Oh, and it made a blistering 142Hp and 178Tq. :D
Not that I know of. Truck ran fine before and after the dyno pulls with no issues.
That is very odd.
I can tell you that the number one cause of stalling in all Toyotas is a dirty throttle body. You may want to check to see of it is dirty or not and clean it if needed.
Will do. Thanks for all the info the other day on the phone. I'm the guy going to Germany that had all the questions about fuel kits. :D
Banned
Gadget said:
That is very odd.
perhaps, but that would cause a continuous issue, no ?? why just on the dyno?
i'm wondering if the truck would do the same when taking it quickly up to speed on open highway to about redline then letting off???
Did the vehicle that was being tested have electronic traction control? Hmm, traction control shouldn't make the engine shut off though.
Is it an automatic or manual transmission?
Perhaps something was overheating. Full throttle at redline is a huge heat producer, engine, tranny, diffs.
