1 - 1 of 1 Posts
Now Introducing the latest add-on to the E-CLIK line of products, our Integrated Lighting Control. The ILC lets you control your rig’s lighting from the E-CLIK ergonomic touch screen, eliminating the need for a separate light controller.
The E-CLIK Integrated Lighting Control is a seamless add-on for E-CLIK letting you control your rig’s lighting from the E-CLIK ergonomic touch screen, eliminating the need for a separate light controller. It supports most standard lights (light bars, pods) allowing you to adjust brightness and strobing effect, as well as KC’s RGB Rock lights that allow for additional color control.
Automotive parking light Vehicle registration plate Vehicle Automotive tail & brake light Grille
E-CLIK ILC is IP67 rated, featuring an O-ring sealed relay enclosure with mil-spec deutsch connectors. The enclosure also features 4 – 30-amp relay output channels. You’re able to adjust strobing & brightness on each channel.
E-CLIK ILC will be available to existing E-CLIK installations, requiring a replacement main harness & update to the ECU/Touch Screen, or as an optional addition to new E-CLIK orders.
1 - 1 of 1 Posts
