1 - 11 of 11 Posts
On my 2002 TRD non-ABS Tacoma I tryed to do the locker mod where you ground the GRAY wire so you can use the locker in 4H/4L and 2WD. I was loocking at the pics that show the Gray wire in the #8 pin between the BLACK/WHITE wire and the GREEN/YELLOW wire. Well my truck has a PINK wire insted of the G/Y. I grounded the GRAY wire anyways and all it did was put the truck in 4WD. Has anyone seen this? Thanks
That's not right. I didn't have a grey wire either, but I grounded the wire that was in the same pin as the diagram. It's an easy fix though to put it back to stock, just patch it with some more wire. At least you haven't screwed yourself. Yet.
no i have the Gray wire but when i grounded it all it did was put the truck into 4H
Pretend the colors mean nothing and do it based on the pin location. That's all I was trying to tell you.
x3. the color in the write up is just for reference and is meaningless in of itself.
Discussion Starter · #7 ·
ok i see.i looked at it agean and i went by the pin location i had the right pin.the #8pin
then try the grey wire...
Discussion Starter · #10 ·
the gray wire is the #8 post.i grounded the end comming from the loom.
1 - 11 of 11 Posts
