Can you give us one good reason why you would make a dumbassed post like this?97TacoDude said:Put the truck in a large vacuum chamber and listen for the hiss. It will be very quiet in the chamber and the air will come out of the leak instead of go into it.
I could, it is that lack of attention as a child syndrome.TRDOLMAN said:Can you give us one good reason why you would make a dumbassed post like this?
Spray carburator cleaner around the hoses and intake system. Starting fluid has a very low flash point and can sometimes be very volitile.BradleyD said:Anyone know a good way to hep pinpoint a vacuum leak other than just a visual inspection on all the hoses?
Maybe we can stick you in a vacuum chamber and listen to you hiss.97TacoDude said:Put the truck in a large vacuum chamber and listen for the hiss. It will be very quiet in the chamber and the air will come out of the leak instead of go into it.
A) He's retarded. I guess you can't really pick on people for being retarded since it's not their fault.TRDOLMAN said:Can you give us one good reason why you would make a dumbassed post like this?
Hahahahaha!tbplus10 said:Maybe we can stick you in a vacuum chamber and listen to you hiss.
Tim
