Sorry guys, this isn't for a taco, but maybe some of you electrical gurus can help.
On a 96 Explorer(4.0 V6), we can't get the battery to stay charged. I had a friend change the alternator and put a new battery in it. WHen I got over there to check it out, the battery voltage was only about 12 volts (should be about 14.4). There was continuity b/t the alt and battery, so I removed the alt and exchanged it under warranty. I had them test the old(new) one and it was putting out the proper volts on their machine so I was a little stumped.
I got back and put the new alt in and fired the truck up. There was still only ~12 volts at the battery. I checked the output at the alt and it was giving me an inconsistent range of voltages from 1.2 mV------12 volts.
Well, the truck is dying again because the battery won't stay charged, so I need some suggestions/ advice. Why won't the alt put out the correct voltage when installed, but it will on the test bench?????? Is there some other component that I need to be looking at??? Help!!!!!
check for loose grounds and also check to make sure all connections are clean on both positive and negative sides.
Row Row Row your Boat
thats where I would start. check grounds check grounds check grounds
I had the same problem on my 4runr and I traced the ground wire from the battery, it was going to the fender. I put the ground on the engine and that fixed my problem.
hope that gets you somewhere Steve. if your conections are all good and your ground is good. then I don't know where else to lead you.
oh ya one more thing, have the battery tested. I have bought a new battery that wan not good before.
