1 - 3 of 3 Posts
So I thought it was just my starter that was bad since when I would turn the key about 2 hours ago, all it would do is click, and I was able to push start it to get home. I just went out to my truck to see if it would start, and the electrical is going crazy! just opening the door causes about 4 (from what I can hear) relays to be clicking on and off about once per second in the engine compartment, the door ding is going at a faster rate, random lights (blinkers, dash lights) are blinking and its just going nuts. I can't even tell if the starter is getting any power now over all that noise. This goes on for 5-10 seconds after I close the last door then it all stops. Where do I start? It's possible the electrical components somewhere got wet from wheeling today, if that helps.
sounds like your alternator may be toast and let your battery go completely dead. Check your battery voltage with a meter. sometimes things get all weird when the voltage gets below 10 volts.
fixed, new battery + new starter
1 - 3 of 3 Posts
