There is a linkage under the truck next to the frame and below the driver's door where you can tighten the cable and remove the slack. 5 minute or less quick fix!Passhawk said:My emergency brake is loose, I have to pull it back really far in order to make it barely work. I get worried parking on hills. Is it as simple as going uder and tightening up the cord? Or is there more to it?
Just look near the frame behind your driver's side rear tire. You'll see the linkage. You just need a small wrench or set of vice grips. Tighten the nut on the linkage to tighten up your ebrake.Passhawk said:My emergency brake is loose, I have to pull it back really far in order to make it barely work. I get worried parking on hills. Is it as simple as going uder and tightening up the cord? Or is there more to it?
Mine did this yesterday... Never it off over night if not it will be frozen in the morning.pportera said:Now that Winter is here......
My E-Brake will not disingage untill like 30 minutes of driving with the rear brakes on....
The handle in the cab will release but the cable is like froozen or something.
Any body know of any cheap tricks to fix this?
I looked under there and i dont see any mud or anything that cold freeze??
It does this only on cold mornings.
Any ideas???
P
As long as the rear brakes are within specification, then they should be left alone. The emergency brake is used to adjust the rear brakes after installation, and keep them in adjustment, with each time it's pulled. If the e-brake has too much or not enough play in it, it should be adjusted.boophoenix said:You would most likely just need to adjust up your rear breaks. This will take slack out of the cable and reduce the extra stress placed on the front breaks when the rear are out of adjustment.
If you have a lot of break dust on your front rims ( black dust look ) this is a sign the front are grabbing more than the rear.
check the adjustment of your rear shoes first then tighten up the cablePasshawk said:My emergency brake is loose, I have to pull it back really far in order to make it barely work. I get worried parking on hills. Is it as simple as going uder and tightening up the cord? Or is there more to it?
The parking brake should have 12 to 18 "clicks" as it travels from released to locked. If not, the brake shoe clearance should be confirmed to be within specification before the parking brake is adjusted.STOMPER said:I thought thats what the self adjusters where for? And they work every time you back up and apply the brakes.
Now when my e-brake cable would start getting loose (where i would have to pull the e-brake handle way out) I change the rear shoes. That in turn tightens the e-brake back up.
AK98Taco said:As long as the rear brakes are within specification, then they should be left alone. The emergency brake is used to adjust the rear brakes after installation, and keep them in adjustment, with each time it's pulled. If the e-brake has too much or not enough play in it, it should be adjusted.
My point: the e-brake adjusts the rear brakes, not vice versa.
Not a rant, just making clarification.
FYI, I had a 2004 4X4 d-cab 3.4l V6, with only ~9000 miles, ebrake was loose since days 1 and finally I decide to jack up the rear, take off the wheel and do the shoe adjustment, I have to tighten 20 click on left and 15 click on the right side, and now my ebrake is normal.Passhawk said:My emergency brake is loose, I have to pull it back really far in order to make it barely work. I get worried parking on hills. Is it as simple as going uder and tightening up the cord? Or is there more to it?
Drum brakes are pretty easy to tear apart and rebuild. The biggest thing is getting the springs off and on, as certain ones are quite tight.boophoenix said:Thanks for the "Not a rant, just making clarification". I'll have to investigate mine more as it hasn't done any self adjusting in quite a while now. I have yet to ever own a vehicle that the self adjusters worked on so this could be a new thing if I can get mine working. I had to adjust mine last year as the front were doing about 80% of my breaking. Looks like time to disasemble the rear drums and see what's up in there.
check the brakes, then adjust as nessasary.Passhawk said:My emergency brake is loose, I have to pull it back really far in order to make it barely work. I get worried parking on hills. Is it as simple as going uder and tightening up the cord? Or is there more to it?
And this is a Cheap Trick how?Passhawk said:My emergency brake is loose, I have to pull it back really far in order to make it barely work. I get worried parking on hills. Is it as simple as going uder and tightening up the cord? Or is there more to it?
and five years oldIsn't this the cheap trick forum.............
Everyone is going soft around here........how about some public moderating
I miss DICK
come on you wussy's flame some people
jezus H Ka riced
