I sprayed my engine last night with simple green and hosed off, then started the engine till it warmed up and dried. Then this morning, I started my truck, and began to reverse when the engine began to cough. Its was shaking like if it was turnin on and off. I put in neutral, hit the gas a few times, incase some moisture got in or something, and it was fine. Then about 30 miles down the road doing 70, and pushed the gas to go faster, and i got the fluttering again, I could not go faster, just could keep my speed. And then the engine light came on. And I keep driving. Then about 5 miles further it went away as well as the engine light and I got to work. Then, going home did the same thing. I have the Deck Plate mod, and last night, i screwed in the plate. So I did not make that mistake. When I looked into the air box this morning, it did have a little water in the corner. So my guess is, Since I have the deck plate mod, got a little water in teh air box, and have the K&N filter, it has to be my Mass Air Flow censor. Any help would be great guys. I am going to clean it right now with elect. contact cleaner from radio shack that is the non-resadue. HELP.....
How do I find the spot on this MAF Sensor to spray. I have a 98 V6
