I recently bought a new 2007 Tacoma Prerunner (4cyl, 5-spd), and I am having problems with the engine revving when it is in neutral. It happens in one of 3 ways:
1. rare: when taking the truck out of gear, for example shifting to neutral from 5th gear and coasting. The engine will rev very high (up to 6000 RPM if I let it).
2. also rare: If I cancel cruise control, the engine will rev (again, up to 6000 RPM or more)
3. very common (this happenned probably 50 times or more during a few days of driving): When shifting from 4th to 5th gear, I put the clutch in and the engine revs up very high (again 6-7000 RPM) as long as the clutch is engaged.
I have found that I can "fix" the problem by manually revving the engine (after that, it will go down) or by shaking the stick back and forth a few times in neutral (under condition 1 above).
I only have about 3000 miles, and I took the truck to Toyota. They had it in the shop for 2 days, but they can't find any problems. One thing that seems weird: I live in the SF Bay Area, and it doesn't seem to happen locally. The problem (so far) has only occurred when driving in the mountains. The most common way for it to happen is shifting from 4th to 5th when driving up a hill with the gas pedal pressed all the way down just before shifting.
Questions: Does anyone else have this problem? Is this potentially damaging anything (like the clutch)? Is this normal? I am pretty certain it's abnormal, but Toyota seems to be telling me they can't fix it b/c nothing is "wrong." Not sure what to do next, but I'm not happy after dropping over $20,000!
Scott
Scott
