I am currently having a really nice custom trailer built for off road. It is basically an open utility trailer. I want to run a single deep cycle battery set up for on board power. Not running a fridge or anything big. Maybe a cell phone charger or some lights. My wife may want to run a 12v hair dryer.
Ok so here is what I want to do. I want to mount the battery in a sealed type box and have it be able to charge from the 7 pin connector from the truck and also from a small solar charger when not in use and on the trail. I have a 400 watt inverter at home w/600watt peak. I also want to have some cigarette outlets. Anyone have a schematic or parts list? I'm not sure what all that I need to make this work!
I am also a member on expedition portal if you have any suggestions from there.
Blessings.
Discussion Starter #2
nobody?:dunno:
STITCH - Come and Take it!
I could guess, but I never done it... so did anyone on ExPO respond?
I went with an solenoid isolator kit from this guy
http://www.12voltguy.com/product.php?productid=17578&cat=258&page=1
Super easy to set up and very effective. Next I bought a fuse box:
http://www.wiringproducts.com/contents/en-us/d136.html
and a grounding bar or busbar:
http://www.google.com/search?q=busbar&hl=en&safe=off&client=safari&rls=en&prmd=ivns&source=lnms&tbm=shop&ei=-LPFTd2INoaWsgPFxvinAQ&sa=X&oi=mode_link&ct=mode&cd=5&ved=0CDgQ_AUoBA
That's a start. obviously you will need plenty of 2ga cable, connectors, wire, loom, etc.
