1 - 8 of 8 Posts
I am putting my truck on the market. I do not have the time to go on trips for which the truck was being built for. Here is a great daily driver and off road rig. I daily drive this truck right now and have taken several long distance trips in this truck and would not hestate to do any trip in it. The truck is very reliable drives ad ride good too.
Basic truck info
-1993 Toyota Pickup SR5 4wd extended cab V6 with manual tranny
- 207,000 miles on truck
-engine runs great with no misses, oil loss, or smoking.
-A/C works and blow extremely cold air
-Factory sunroof
-split rear window
-all windows tinted (tint is faded a little bit)
-Carpet is faded a little bit and small tear in driver's seat
-no cracks in dash
-body has some dents, bigges one is passenger rear corner behind bumper. look at pictures and you can see
-body had only 1 rust spot and I fixed that, however it was never painted to match the rest of the truck. driver's side of bed just in front of wheel well. You can see this in picture as well
-under body is in good condition too. frame is clean
Modifications:
-Solid axle swap
-Sky spring hanger, shackles, and axle "Toyota" truss
-Marlin 4" front springs
-Marlin crossover steering with steering stabalizer
-Sky's axle widening kit (NOT WHEEL SPACER!!!!)
-Completely rebuilt '85 front axle
-Marlin front diff breather
-new rotors with new V6 calipers and stainless steel braided brake lines
-Front diff is a V6 diff with 5.29 gears and Tru Trac
-Custom high angle front driveshaft
-Rear Marlin long leaf spring conversion with 5" Marlin springs
-axle is properly shimmed to correct driveline angles
-rear diff is V6 with 5.29 and Tru Trac
-rear Marlin diff breather
-Load Sensing Proportionin Valve is operational if needed. I have it in a fixed location now though
-brakes, seals, bearings in rear are 2 months old.
-ARB snorkel with ISR mod done to the intake.
-Optima Red top battery
-Headlights upgraded to bulb design 100W/80W bulbs with upgraded wiring harness. I made one like 4crawlers.
-custom exhaust with new Magnaflow cat and Flowmaster muffler 2.25" diamter
-(5) American Racing Outlaw II rims with (4) 35 x 12.5 R15 Pro Comp Xterrains 80% tread and (1) BFG All terrain (ful size spare) 60% tread
-Fiberglass truck cap with ORU safari rack and (4) Hella 500 lights with wiring harness
-Hinged soft tonneau cover
-TJM front bumper with Milemarker 9500lb winch and wireless control.
-Warn SDB-160 100,000 CANDLEPOWER dual beam DRIVING/SPOT LIGHTS
-D-rings and anchors in front
-D-Ring in reciever in rear
-Kenwood CD, AM/FM, MP3, WAM, reciever
-4 Kenwood 4" speakers (2) in front and (2) in rear
-custom overhead console with CB and light switches
-scanner in ashtray bay
-6' CB anntenae in rear of truck
-2001 Tacoma center console (look at interior pictures)
Maintenance
- Oil change every 3k - 4k miles with only synthetic oil
-K/N air filter
-complete tuneup 5 months ago with plugs, wires, dist, rotor
-replaced radiator and hoses 1.5 years ago
-thermostat and water pump replaced same time
-timing belt replaced same time
- al brakes less than 6 months old (rear is 2 months old)
- fuel pump and fuel filter replaced 2 years ago
-all emmissions replaced last month to pass emmissions:
egr and egr filter
pcv valve
pair reed valve
charcoal canister
EGR VSC
o2 sensor
-AFM replaced 2 years ago
-90% of vacuum lines replaced
-tranny, transfer case, and diff all had fluid change 2 months ago. tranny and transfer fluid change 4 times in 3 years.
-diffs done every 6 months unless axles in water.
-truck waxed and polished once a month, washed 1 -2 times per week especially during winter.
-blower motor replaced 2 years ago
- clutch replaced 3 years ago
- injectors cleaned and balanced 3 years ago. One of them ticks a little bit, but very hard to hear
-new u-joints in rear driveshaft
additional parts with truck
-another set of (4) 16" American Racing Outlaw II with 315/75 R16 Pro Comp Allterrains with 70% tread left
-5" Marlin front springs
-6" marlin rear springs
-downey headers new in box never installed
-soft hinged tonneau cover
-truck tool box
-fiberglass truck cap with ORU safari rack and (4) Hella 500 lights
-bunch of spare parts, tie rods for crossover steering, hoses, etc...
I am asking $7900 O.B.O. for everything and am open to trades.
please e-mail me at [email protected]
If you want to see the truck I work at
4Wheel Parts
10865 Brookpark Rd
Parma, OH 44130
bump.....
1 - 8 of 8 Posts
