1 - 2 of 2 Posts
I'm in the process of configuring a rear bumper for my '99 Taco and noticed that a support is welded right above the rear shackle hanger in the frame. My plan was to slid another c-channel in the frame and weld the two together. Can't do it with that support in the way. Would a heavy flat bar on the outside of the frame work? Need some advice from the experts out there. Thanks in advance.
I use 3/8 or 1/2" plate for rear bumper mounts, you could run some 1/4" plate on the outside of the frame, but boxing the inside of the frame would be the best, as it is a pretty wimpy back there, hope that helps, Steve.
1 - 2 of 2 Posts
