DCabTaco said:Is the ball joint in the Fabtech 6" lift kit the same in diameter as stock BJs? Actually what I really want to know is if the hole on the FT steering knuckle the same size as the one on the stock knuckle.
My kit came with stock upper ball jointsjoeylead said:When i installed my fabtech lift, I used their balljoints because of the grease fitting. If a stock one will work, I would reccommend using one because after only 4 months the rubber is already showing signs of cracking.
