Ok so heres the deal,
I would like to get a fabtech 6" lift for my taco, and a 3.0" cornfed spacer in the front. For the back however, I'm somewhat confused. I was leaning towards a Fabtech or ProComp AAL in the back, the fabtech is 2" and the procomp is 2.5". How much higher approx. is the back than the front on a stock taco? Basically, would a 2" or a 2.5" level it out better? Also, if I were to get that 9" of lift, what sized tires would you reccomend with that? I'm leaning towards some 35s, but what would be the biggest size I could fit on there? - Mabye I should add a 3" body lift to that to allow for some bigger tires? Sorry for the questions, I'm still a newb, and to make things simpler, I've listed all my questions in number format below.
1.) What AAL would level out the back better, a 2.5" or a 2"?
2.) Whats the biggest size tire that will comfortably fit on a 9" lift (6" FabT, 3" Spacers)
3.) Whats the biggest size tire that will confortable fit on a 12" lift (6" Fab, 3" Spacer, 3" Body)?
Thanks again,
Brendan
Thanks again,
Brendan
