1 - 20 of 51 Posts
Hoist The Colors!
If we were able to offer the rear axle (complete drum to drum) equipped with the e-locker and 4:10 gears for around $900.00 shipped (lower 48 states) would anybody be interested?
These would be complete axles with the e-locker actuators. The only thing you would have to purchase extra would be your wiring and switch. The applications would be from the 01-04 year models, but you could make them fit the older models as well.
If there is enough interest in this we will do this deal. So post up here if you are definitely interested.
That is a screaming good deal, y'all.
Would it come with at least the axle harness part, Shannon? Otherwise sourcing the connectors could be a PITA but they could splice into the axle harness real easy.
wow thats so cheap, i paid 850 for mine and it was out of a j-yard with unknown mileage
Hoist The Colors!
Nope, no wiring would be included with that price. But wiring it should not be that difficult of a problem...as you are aware. They could even opt for the cable actuated deal from Downey if they don't want to mess with the wiring.
Look into your parts book and see what the part number is for the harness that connects to the axle. There should be something there and it shouldn't cost much for three connectors and some wire.
Most folks have had bad experence with that Downey cable thing.
I can add something to the switch write up if necessary. Still it's a good deal.
None, I think.
Damn brand new brakes, bearings and the whole shebang for less than a grand. I am amazed and I'm tempted myself.
Hoist The Colors!
Oh for sure, the connectors and wiring should not be a problem if people want to order that as well...I'm just saying that the $900.00 price will not include those items.
Yep that much I understood and I'm not bitching.
So quit dallying around and look it up already. LOL
Hoist The Colors!
Discussion Starter · #10 ·
Dude, I'm just fishin right now...I gotta see if I get any bites first! ;)
Look at yer float already. Ya alreay got three bobs. Some damn fisherman you turned out to be. They ain't gonna jump in the damn boat ya know. LOL
Hoist The Colors!
Discussion Starter · #13 ·
I've gotten a couple of good bites...a few more and this deal may be a go!
Deal Master
Shannon- Great Price-
Consider what you are getting guys
An ARB Locker alone costs ~$700, plus install $$$, plus Air source $$$
You are getting a complete rear axle- drum to drum-
This means new axle shafts, new bearings, new brakes, new gears.......
Deal Master
So if the spec- application is from 01-04-
That means they will set up for ABS, correct.
EDIT- This should not matter for Non-ABS- trucks since the connector/sensor could be capped or even discarded-
Hoist The Colors!
Discussion Starter · #20 ·
You are correct, these will be ABS equipped axles, but as you mentioned, this will not be a problem for non-ABS equipped trucks.
1 - 20 of 51 Posts
