1 - 10 of 10 Posts
I have the flares, and I have 37s waiting for a lift to be installed.
The main reason for the flares were because of a fix-it ticket.
Ohhh - so you must have some aftermarket wheels with less backspacing (cuz my 33x10.50 don't stick out past the body - and therefore my opinion on flares)
What kind of flares did you get, how does the manufacturer say to install them?
Well I bought them used for $75, The are painted to match my truck so I thought it was a good deal. Bushwhckers. Since they are used they dont come with anything to mount them. (Yes the tires stick out about a 1" past the fenders.)
I was hoping just to get a warning, but i got the ticket instead. So i have to fix it or pay it.
I have riveted bushwackers on in the past, but I would suggest something else. Theose things break if you even get close to a tree or rock.
I have a set in my basement, they attach from the bottom side using the factory wheeltub screws. I tiook em off for daily use, only go on when I go in for inspection
So would a good way be double back tape and sheetmetal screws? I was thinking about weather stripping with sheetmetal screws also.
If I remember right they used the same screws that hold the water sheilds on in the fenders. The flares even had the holes started in them. When installed correctly you wont need tape because the screws pull the flare into the body aginst the rubber weather strip on the flare. On my 91 I had 32x11.5's with after market rims and it looked good to me.
Discussion Starter #10
Well the holes dont line up right on mine, so i thought i would just put a few sheetmetal screws in each. Sound good or should i try something else?
1 - 10 of 10 Posts
