1 - 16 of 16 Posts
Borrowed my cousin's welder and taught myself how to weld. :eek: Decided to build a bed rack for first project. Thought no big deal if I fuck that up. :p
Actually turned out pretty good. For a rookie anyhow.
First couple practice welds were ugly but by the third one, I started to grasp on.
First weld
Second
Third
Still not perfect but good enough for me...for now anyhow. I know, I need to clean the metal first. Did that when actually welding rack.
Drilled bed and mounted brackets. Then began to cut pieces.
Started tacking in outside frame of rack
Got everything tacked and it seemed to fit pretty good.
Here it is all welded up. Still need to weld in horizontals but ran out of time.
I plan on drilling and tacking in some 3" bolts up through two of the brackets to mount Hi-lift. And maybe weld another bracket on opposite side to hold other camping accessories...shovel, wood mull...whatever.
Oh and Angus1...i actually did the work myself this time. Yes, that really is me under that helmet. So....:flipoff4:
Now let the ball busting begin. :D
Nice first project. Couple welding tips -
Clean the metal really good, even fresh metal from the yard, as it has a coating on it. You want it nice and shinny, can also wipe down with acetone to remove additonal contaminants after grinding.
Your welds look a little on the cold side - may want to do some destructive testing to see what kind of penetration you got - would suck to be going down the highway and hit a bump only to see your Hi Lift go flying.
Slow down and make little e's or c's lapping between the metal. The test welds look like you have the wire speed a little on the high side..
Keep practicing and you will get better.
Thanks for the tips. I did clean the metal with a grinder when welding actual rack. The test weld...i did not. But I will do a little "destructive testing" Good idea. I probably should have showed some close ups of my inside corners. Most of them turned out really nice. "Stack of dimes" nice. I found that inside corners are easiest. Plus, the inside corners came later in the project also. Wire speed seems to be an issue that everyone points out. I'll mess around with that next time. Again...thanks.
Sounds good. I hate welding outside corners, I tend to burn through quite a bit :)
It's nice being able to build your own stuff :)
yes it is. Just talked to my bro-in-law. He built a "catch" rack for his log splitter at the same time I was building my rack. We are gonna go halvsies on a welder this weekend :)
Got the fever now!!!
The inside corner is easy cause everything is concentrated in the corner. Put a bevel on your material before welding and it will help you some with that.
You need to practice some, use your leftover scrap's and have some fun. Like was said stick to pattern, the C-pattern is good to start. Slow down and watch the puddle of the weld. Once you started look where the wire feeds the puddle. Once you get control of the puddle the world is yours:cool:
So...once I control the puddle...the world is mine? I like the sounds of that! Mmmmuwwhaaaaahaaaahahaha!!!!!! :mad:
Discussion Starter #9
Ha. Thanks for the tips though...once I buy this welder, I'm gonna start practicing. I have fun building shit
Discussion Starter #12
Also, move anything out of the way that may burn or catch on fire....like that toneau cover in the bed. :welder:
Ha. I was wondering if anyone would see that. I was actually hoping it would burn. :D
Discussion Starter #13
Picked up a welder over the weekend. Continued on the bed rack. Below is one of my better welds.
Discussion Starter #15
Uh...no Didn't disconnect battery. Just tacked it in a couple places though. Hope I didn't fuck anything up. Everything seems ok.
Not flux core. Mig
Finally got it done and bolted it to bed (unpainted) two weeks ago for a camping trip. Wanted to test it out before paint in case I wanted to add or change something. Glad I did cause I noticed some things that I didn't like.
It's finally all done. I just painted it last weekend. I'm heading out to PA Grand Canyon for a fishing trip today. I'll post some pics of the rack when I get back.
Then you guys can start bustin my balls.
1 - 16 of 16 Posts
