1 - 3 of 3 Posts
The passenger side power window on my 01 extended cab stopped working. Are there separate fuses & relays for each window?
check the connections at the window switch both in the drivers main control and on the passenger door. My '97 started acting up a few months ago. but mysteriously started working flawlessly again. makes me think that the connections either get corroded or loose.
Thank you for the quick response.
I thought if might be easiest to start tracing fuses & relays first.
Neither switch works to make the passenger window move. It doesn't seem like they would both go at the same time, but still worth checking.
1 - 3 of 3 Posts
