1 - 12 of 12 Posts
80 series axles
These axles are the strongest that toyota put out and hold up very well. I know people that run up to 40" tires on them. The rear diff is offset though, as with all cruiser diffs.
Long lost Taco Owner
91toyota4x4 said:
How far offset is it? And to what side?
They want $1200 for it so I am really considering buying it.
The rear diff also has a larger ring gear. I also believe that there are no high steer kits available for the front axle.
91toyota4x4 said:
Well I called today and they told me they want $750 for the rolling chassis now so we are going to get it tomorrow.
What size tires are these axles reliable to?
Stock birfields and inner axle shafts are fine up to about 37"...after that point, I'd recommend upgrading both the inner axle as well as the birfield joint with stuff from either Bobby Long or another source.
A lot also depends on how you wheel....if you are doing some knarly stuff all the time, then regardless of what you throw in the housing, you are going to break stuff. It's plain ole physics...
Good luck on your new front elocker. Well worth it.
Banned
These are the best axles Toyota ever made.....
Anything else is a Major step down in strength. The Birfield is 50-70% larger than your Mini Birf and at least twice as strong. The ring makes a Taco ring look like a playtoy. These are 1 ton axles hidden under the wifes grocery getter. $750 is a screaming deal. There are several companies that say they are working on a high steer for them but one hasn't yet materialized, the problem is the high and low mounting of the arms. As they become more popular they will become available. However they hardly need it with the tie rod location :rolleyes: .
The front axle is a high pinion 8" diff but the rear diff still has the larger ring gear. The reason why you would need high steering is so you can run reaf springs with the axle. If you are running a linked suspension the high steer does not matter as you said.
if you need some help once you get to the install, i can send you pictures of how i did mine. we run them with stock internals on up to 42" tires....and abuse them. I made my own spring perches and High steer with no problems yet....
1 - 12 of 12 Posts
