what does it mean when your check engine light is flashing? my check engine light has been on for a while, cause of the air/fuel sensor. and today it started to flash
I found a spark plug wire is f-uped. down around the sprak plug, and i dont know how to get the rubber peace off around the spark plug.
Bear's Chauffeur
Did it break off down in the tube where you can't get a hold of it?
Can you grab it with some needle nosed pliers and try to gently pull it off without tearing up the remaining rubber too bad?
