was going to replace the front brakes this past weekend. i read the post on custom tacos in reference to front pad replacement. when i took off my front tire i discovered my caliper was a one piece unit. i took the bottom 17mm bolt out and removed the top and the whole caliper came off. not like what was in the post i was reading. i think that post is refering to a 2wd instead of a 4wd. after removing the caliper do i remove the small spring like retainer and the tow holding pins? will this allow the pads to come out ? i ran out of time and had put it back together. thanks to all replies.
96 taco 4x4 ext cab v-6 auto
