1 - 18 of 18 Posts
This is a fantastic rig, I get 18-21 mpg to and from work. It goes many many places. Its just not practical for me with a new daughter. I probably wouldn't use it like intended for too many years and don't have room for 3 rigs.
Drivetrain
22RE, 160,xxx miles
3-core HD radiator
HD PS Cooler, with Amsoil ATF
Amsoil everywhere (but engine due to TC replacement)
Centerforce Heavyweight flywheel
Centerforce DF Clutch
4.88's F&R, genuine gear (speedo is w/in 1%)
ARB rear air locker
Rear CV drive shaft
Warn Premium Hubs
Performance Mods
K&N Air Filter
LCE Ceramic Stainless 4:1 Header
Carsound hi-flow 2.25" cat
Flowmaster 60 series 2.25"
Custom 2.25? ?hi-clearance? exhaust
Larger 4runner IFS front Brakes
Suspension
Procomp Stage II 4" front
25mm HD Torsion Bars
Trail-Gear 56" 3" rear leaf springs
AllPro shackles .75" Lift
ORS /\ shock mount
RS9012 rear, RS90xx front
Rancho steering stabilizer
Protection
ARB Bull Bar w/ winch mount
Allpro HD sliders
Allpro HD rear bumper, 2 shackle mounts
1/4" aluminum skid plate
Electrical
100 amp alternator, small pulley = 100 amps at 1500 rpm
Optima yellow top
rewired 12v plug, always hot
Rubber
5 x 35x12.50R15 BFG M/T (95% tread)
Do-Dads
ARB compressor with quick disconnect for airing up tires
Shifter mounted locker switch (from a diesel exhaust brake)
LED Shift light wired for locker
IPF Headlight Housings, H4 Conversion
Delta Champion tool box
Spare Parts
Front CV Axle
Air Filter for ARB pump
Front Sway-Bar, with quick disconnects, needs 3/8? spacer
NEW IN LAST 1000 MILES
Radiator, 3-core HD
PS Cooler, aux PS fluid was flushed
Fuel Filter
Fuel Injectors sonically cleaned and match flowed
Timing Chain
Head Gasket (Head shop said head and valves as good as new)
Centerforce HD Heavy Flywheel (increases inertia)
Centerforce Dual Friction Clutch, Throw Out bearing, Pilot bearing
LCE Ceramic Stainless 4:1 header
Carsound hi-flow 2.25 cat
Flowmaster 2.25 60-series muffler
Wheel-bearings repacked
Starter rebuilt, professionally
asking $5000
::bump:: for a clean looking rig, looks like fun!
so would you take off that ugly chrome for 5000?:D
Its original AFIK (sport package), and it would probably look worse at 15 years of sun on the rest of the paint... but I am not a huge fan of it either...
ohhhhhh ahhhhhhhhh
Bump
:bump: for a nice looking truck w/lots of mods but I think you are better off posting it on autotrader
Discussion Starter · #12 ·
thats coming shortly.... this is easier :D
1 - 18 of 18 Posts
