1 - 1 of 1 Posts
FS: 2001 Tacoma TRD 4x4 SC long travel
Finally parting with my truck, hurts me to see it go since i have put so much work and over $20,000 dollars into it but it just doesn't get the use it deserves any more. Just sits in my driveway and it is time to go, every thing works perfectly, just took it out through charouleau gap with zero problems. Runs great, manual 5 spd, V6, TRD 2nd gen super charger, cold AC and a long long list of modifications. the super charger doesn't have any more than 15k miles on it. Please text with any more questions, some one is going to get a lot of truck and hardware for a VERY good price, the parts alone are worth more than this if you took it apart and sold them separately.
as seen on TV - http://www.ttora.com/forum/187-long-travel-suspension-tech/186334-rear-leaf-setup-info.html
custom bumper, 1/4" center section, 1/8" wings
warn winch, mounted feet out
aluminum fairlead
specta winch rope
custom 3/16" skid plate
3 front flood lights
fiberglass fender flairs
2" body lift
radiator drop
supercharger (second gen)
zentronix wide band afr gauge
URD short throw shifter
33" MT tires w/ two spares
Camberg long travel
TC gussets installed on spindles
steering ball joints replaced with rod ends (heims), inner and outer with Camburg internal replacement kit
fox external res shocks
fox hydrobumps
front limit straps
rock lights
remote winch control
in cab light control
cb radio
custom bed cage
tool box
dual batteries in rear
bolt on rock sliders
on board air with sliders as air tanks
fiberglass fenders
Deaver f67 Springs
18" triple bypass 3" king shocks
rear limit straps
rear electronic locker
locker solenoid skid plate
small custom bed
larger custom 300+ mi tank (stock pump and sender)
rear light bar
magnaflow muffler (pretty quiet)
tire gate (dual)
custom rear bumper on extended frame rails
boxed rear frame
1" wheel spacers on rear only (close to front width)
List Date: 9/8/2016
For more info, click here to view the original listing: FS: 2001 Tacoma TRD 4x4 SC long travel
This item is no longer available.
1 - 1 of 1 Posts
