I finally installed the kit. My idle settled down. There are some flat spots in the power based on my gut feel. I now want to load the software onto a laptop and see how well the pre-loaded 3.4 2001 program from Gadget is doing. Are the only instructions the ones on the SplitSecond site? Perhaps I misplaced instructions from Gadget, though I did not see any on his site. I can load the software easily enough, is it obvious how to save the preloaded configuratin to laptop memory before I begin experimenting to make sure I can "reset" back to his map?
I looked on the Delphi site for some of the old threads, but it seems I can only look back three months. It has been far longer than that. Thanks.
Vince
Installing the software is easy. Once installed open it and create a new customer(file/new customer). Then you want to connect to the FTC1 via a serial cable and establish communication by pressing the "ECU Connection" button. Next go the the (maps/fuel maps) window and click on the "Read ECU". You will see the tables loaded on the FTC1. Now close the window and then from the file menu exit by "Close Customer.
Repeat by creating a new customer with a different name and then make changes as needed to your fuel and timing tables. After making changes make sure you "write to ECU" so that the FTC1 is loaded with the new values. Also make sure that your ignition is on to establish communication from FTC1 to Laptop.
Robert
