1 - 9 of 9 Posts
I am running the stock pump as well. Been holding up fine now for 3 years in my cell.
I have this same pump brand new never used if you are interested. I was going to run it but I modded my stock sending unit/pump to work with my fuel cell.
ive heard of people doing that but ive also heard that its more work than its worth.
what needs to be done to run the stock setup??
I was running the stock setup in my cell and it worked ok. The only problem is if you have a problem with it it's a pain pulling the pump out in the middle of the desert. i now have the kartek(pierburg) pump and it's working good so far
[/IMG]
Basically cut i hole in the cell, make a flange(ring with bolts sticking up) that goes in the inside of the cell to bolt the pump setup to
Here is mine... vent and return on the left, main on the right.... and I drilled a hole in the 45* filler to run the wires to the pump. I tap into the factory lines just below the cab.
1 - 9 of 9 Posts
