so as the problem goes, we have found that when the truck was running things were fine but when the brake was pressed it would cut out the fuel pump. We pulled the plug off of the brake pedal sensor to try to jumper it out and bypass the problem, and now its plugged back in and the truck wont even start, it just cranks over. I know it's a fuel/brake problem in some wire somewhere, so I was wondering if someone had a wireing diagram for the fuel pump on a 96 2.7 that will hopefully shed some light on the problem.
and all fuses are good
