well my headlights don't work anymore...first i thought i blew out my after market lights...so i decided to put the stock ones back in and they don't work either...so is the fuse box blown?
I doubt the entire fuse box is blown, lol, but the actual fuse in the box may be blown. That or a bad relay. I'm gonna go w/ the fuse 1st and foremost! Peace, Wes04RedLobster said:well my headlights don't work anymore...first i thought i blew out my after market lights...so i decided to put the stock ones back in and they don't work either...so is the fuse box blown?
can you explain in detail how you wired your aux lights? that will be your culprit.04RedLobster said:well my headlights don't work anymore...first i thought i blew out my after market lights...so i decided to put the stock ones back in and they don't work either...so is the fuse box blown?
If it's the fuse that blew you don't want to start upping the fuse size to keep your lights working. The fuse is a safety device based on the size of the wire. Fix the problem, don't band-aid it or you're asking for a melted harness or a fire.04RedLobster said:well i didn't know that the fuse were so cheap...lol i guess i'll switch them out to 15 amps...
Do NOT up the amperage on the fuse! that can cause a fire. you must figure out why the fuse blew in the first place. During your install of your clear corners you must have grounded something out to blow the fuse. Install the same amp fuse and then track that down. trace all wires pertaining to your install looking for nicks/cuts, etc or any bare sections that might touch metal somewhere.04RedLobster said:well i went to the dealership..and they told me the fuse was blown..like i already knew it..but they were being a little dick and saying that my clear turn signals blew the fuse...and i'm like ah... they are stock...and i'm like do mean the clear corner light? and he's like yeah...i told him that's impossible because there is no bulbs in there because i took them out...but you know dealership...they well be stupid and told me if that happens again they won't cover it next time...
Hey! who told you about my harness?? LOLSteveO said:you're asking for a melted harness or a fire.
Figure out what's wrong with them would be a good start. What have you done to the truck that might have fucked it up?04RedLobster said:so what do i do if the fuse blows out again on my headlights? do i just get another fuse and replace them?
could the bulbs in those new corners be the wrong amperage? Compare the bulbs that they came with to your OE bulbs. If they are different that might be the problem. You'll still need to retrace all your install steps looking for any loose, nicked, bare wires anyway.04RedLobster said:nothing really...all i did was replace the headlight, clear corner lights and the turn signal lights...i was running the headlights for about a week than put the clear corner lights and the turn signal lights yesterday...it worked fine for about 3 hours. I went out with a couple of my friend to go eat and when i turn on the headlights it wasn't working...my turn signals were working and my corners...i don't think i pulled any wires.
are your aftermarket front lights a higher wattage?? I would bet your shorting out due to a melting wiring harness. alot of the bagged trucks put blue headlights or wanna be xeonon ones on their trucks then the shit melts...04RedLobster said:thanks man..i will look at all the bulbs and what watts for the clear corners...
8000k, 6000k etc refers to the color of the lights. Not the wattage. The stock lamps are 55/65 watts.04RedLobster said:yeah i think it was too high.....i'm looking into the PIAA ones..the 8000k...is that too high? should i get like the 6000k? thanks
don't those higher Kelvin figures usually go with HID bulbs?flatlandtacoma said:8000k, 6000k etc refers to the color of the lights. Not the wattage. The stock lamps are 55/65 watts.
