1 - 8 of 8 Posts
KawRider said:
Look at this water injection setup. How do you think it compares to the aquamist you provide?
http://www.snowperformance.net/proddetail.asp?prod=Auto020
I think that the Dyno chart the have posted is BS. I have never seen a Dyno that had HP over Speed? I have always seen them with HP over RPM. Also unless it went 120mph in first gear then the chart has to be BS there are no bumps for the shifts.
Later,
Chris
Smoked Out!
Later,
Chris
hey good catch,... I didn't even pay attention to that, but even before you pointed that out I didn't believe it.
I have seen it before. It's a one gear dyno pull. The MPH VS RPM is just the settings on the dyno meter.
Discussion Starter · #6 · (Edited)
It's a 4th gear pull appearantly. 4th gear is numerically closest to 1:1 ratio. RPM/MPH isn't really a big diff... as long as the HP/TQE increase vs baseline and the curve is fairly constant (Flat) in it's increase. You don't need to dyno a vehicle through more than 1 gear, unless there is an ECU differance in timing/fuel in different gears.
That has been around for a while. It is crude compared to the Aquamist system.
The Aquamist is a true three dementional system unlike that one that increases the injection based soley on boost. It is a lot like those additional injector systems that pump in more gas whether it is needed or not as the boost goes up. A true 3D system is much better.
URD is only going to stick with 3 dementional systems whether it is water or fuel injection so it can be tuned to your exact needs.
1 - 8 of 8 Posts
