1 - 3 of 3 Posts
If i have a detroit and want to regear can I still keep the locker in there?
I may want to regear 4.88 to 5.29 and I currently have detroits front and rear. Will they be able to set up the new r&p w/ the detroits?
Thank you
-wynn
Thank you
-wynn
yea, no problem.
Thank you
-wynn
Yes. The ring gear actually bolts to the detroit carrier and the detroit is designed to work with different gear ratios. Just find a good shop that knows how to install ring & pinion gears and you will be fine. The older model Toyota axles actually have adjusters that make setting up the gears on those axles much easier then the Tacoma axles (non-TRD).
1 - 3 of 3 Posts
