1 - 20 of 32 Posts
· Premium Member
I'm looking to re-gear and wanted some direct opinions for my setup. First of all the truck is a 97' Std cab 3.4 V-6 5spd with E-locker (4.10's)..I run BFG 33x10.50x15 M/T's and do not plan to go larger..I do not drive the truck daily, but when I do drive it it's on the highway to the wheelin' place of choice..The majority of the wheeling I do is rocky, slow and technical. I'm leaning torwards 4.88's but don't want to have a real highway issue..I can't afford the transfer case direction or that would be the way I'd go..Just looking for more input..Thanks in advance..
If its not your daily driver then go for the 4.88's, that will give you some awesome offroad driving. I just got 4.56s for the exact same setup you have, but I drive the truck every day and I couldnt take the high RPMs on the highway with 4.88s. Thats just my opinion though
4.30 will bring your closest to "stock equivalent", 4.56 should be ideal if a little on the low side.
· Retired
Go with 4.56s for commuting on the highway, they will be the best. 4.88s will be better for speeds under 65, and will excel offroad, especially on rocks.
· Premium Member
Does anyone recall the link to a gear/tire size calculator?? I can't seem to find where I hid it..
· Going John Galt
with what you describe, 4.56s. Other than installing a crawler (dual tcase) there's nothing you do with the OE tcase gears.
· Premium Member
Discussion Starter · #11 ·
Yeah... I knew the tcase gears wasn't an option at this time, and the crawler is just out of reach for the ole' pocket..I believe 4.56 may be the better route, but a slower crawl would sure be nice...I didn't wheel it much stock (31's), so I can't really remember how the crawl ratio felt. I figured 4.56 and 33's would crawl about the same as 4.10 and 31's..I appreciate all the info and the links so far..
· Going John Galt
no, with 4.56s your crawl ratio goes up as you wind up with an 'adjusted' gear ratio of 4.28:1 down from 4.10. as suggested, going with 4.30s would get you close to stock at 4.04:1 4.88s put you at about a 4.58 ratio with 33" tires.
· Premium Member
Discussion Starter · #13 ·
That's kinda' what I was trying to say... basically that if I ran 4.56's with my current 33" tire it would have a similar low range feel as I did with the 4.10/31" combo. I really need a "better than stock" crawl ratio for slower travel in the rocks..I really appreciate the specs hytenor..I am a "spec" kinda guy..
I've got 33's like you and I'm going with 4.88's soon. We probably wheel a lot of the same places-Windrock, Tellico, Royal Blue. I desperately need more for crawling but mine is not a daily driver, although it is the only personal vehicle the wife and I have and sees about 11k miles a year-mostly highway. Also, my 4Runner weighs a good bit more than your truck, so you may be able to get away with 4.56's.
· Premium Member
Discussion Starter · #15 ·
Are you automatic?? I really want to get this right the first time, and I really want a slower crawl, but just don't know how much slower 4.56's will be...I know the consequences of the 4.88 on-road but...if I can "crawl" well with 4.56's they'll be the better on road choice..Are you local to TN??
· Going John Galt
better than stock would be the 4.56/33" combo.
if stock is 4.10/31 then 4.56/33 will feel like having 4.30s with 31" tires.
4.30s/33s will feel like having stock 4.10s and 31" tires.
4.88s/33s will feel like having 4.58s and 31" tires.
stock crawl ratio in 4-lo/first gear is 40.36:1
with 4.56s/33s it will be 42.13:1
with 4.88s, 45.08:1 (add a 4.7 Marlin crawler...212:1 hee, hee)
(based on tires that are an actual 33" but you get the idea)
· Premium Member
Discussion Starter · #17 ·
Damnit man, you're just full of figures aren't you....I appreciate the wealth of info..It certianly helps in making an educated decision.
· Premium Member
Discussion Starter · #18 ·
How are your 4.88's on road??
· Going John Galt
I like my 4.88s/33s but I have the 2.7. If I had the v6 I'd go with 4.56 so the hwy rpms wouldn't be so bad. I run about [email protected] 70 but I have a slightly higher top gear than you do.
you can get estimates of rpms at whatever speed with different gears off the calculatar page on the NE site.
with the v6 5-sp you have a 5th gear of .838 and factor the tcase at 1 to come up with top gear rpms on the hwy.
· Premium Member
Discussion Starter · #20 ·
Do you know if a Tundra diff will interchange with the Taco?
1 - 20 of 32 Posts
