Green wire /red stripe. Cut that sucker!
On another thread I was reading about how to stop your buzzer/bell from ringing when you had your truck key on AC and listening to the radio with the door open. There is a little "green wire" with a "red stripe" on it under your dash leading to the ignition. I wasn't able to get to mine under the dash so I just opened that little fuse box door on the left side of my steering wheel and there it was....a little "green wire" with a "red stripe" on the wireing harness connected to the fuse box so I cut it about 2" back from the box in case I want to splice it back for some reason.....No more irritating bell! The bell still works when you have in the start possition or if you don't fasten your seat belt but now I can work on cleaning the inside of my truck with the doors open and listen to the radio without the bell.
This mod DOES NOT effect anything else , It's for the bell/buzzer only. Mike
