1 - 20 of 37 Posts
To keep a long story short I finally found my issue causing multiple misfires and lean bank 1. Blown head gasket.
For all the details here is the original thread: http://www.ttora.com/forum/showthread.php?t=191188
I am not quite sure how my head gasket went, I don't drive like a bat outta hell and my engine has never over heated. The mileage on this engine is around 100k, it is a used engine I bought 4 years ago from ATTARCO and it came with somewhere between 30-60k miles.
After talking with some Toyota mechanics and family friends with mechanic backgrounds we're pretty sure it was probably just a bad gasket.
Anyway, I purchased the full gasket kit (from heads up) from the stealership for way too much :2cents: I'm going to go to Napa and see if they have the Felpro head studs for a better price. I know Kmillan had a problem with Napa giving him the wrong bolts so I may end up supporting the stealership again.
A little under a year ago I did this job on Kmillan's tacoma so I have experience and I have a manual to follow. My only concern is the shape the heads are in since this was such a random failure. Through searching at dismantler yards, junk yards, online and talking with mechanics I will be looking at about $1400 for a pair of heads; of course this is all IF my heads are cracked, warped ect.
If that is the case I plan on just swapping in (another) used engine. One dismantler offered me a 2000 4runner 3.4 for a grand with 98k and I have found a few on CL for around the same price.
Anyway, my apologies for the novel. I figured I would start a thread and post up as many pics as I remember to take for future reference if anyone runs into a head gasket issue.
Pics will follow tomorrow evening. I have already pulled everything off down to the cams
Yes sir, thanks!
Nahhh I was thinkin I should drop a Cummins in it. Thatll bolt straight up right? And give me ultimate wheelin advantage??:rofl::missingto
truck ~n~ tow
As long as it didn't overheat and warp or crack the head.
there shouldn't be an issue.
Not on my Tacoma...
but I just did a head gasket replacement on my pos dd
Was fairly straight forward...
but then it never overheated neither.
good luck with 'er :)
Welllllllll. Good news is, it took me under 3 hours to get it all torn apart and stripped.
Bad news (ish?)
Figured out the misfire: this little fucker was in my third cylinder? looks like a tiny ass nail, thought it might be an electrode but I am convinced it is a nail.
Sooo the bad news i suppose is it pitted my piston a tiny bit, not enough to be a serious problem. It also pitted my head a bit but should be able to machined out. I guess I will find out tomorrow when I take the heads into the shop.
Better news, wont need to do an engine replacement because I found 3 sets of heads, all machined and rebuilt on CL soo thatll be nice?
Anyway here is all the important shit since no one probably read that :flipoff4:
Proof it was a headgasket issue
Service Bolts in (6mm Dia 1 mm thread pitch 20 mm long)
terrible pic but you can kinda see where the nail pitted the piston
random other pics:
These things need to be closely ordered, the passenger side is numbered and in order 1 2 3 4 but the drive side exhaust cam is ordered 4 3 2 1
Expensive ass gasket kit and cleaned up and painted parts..bling haha
NorCal Chapter Pres
No shit. I take it you find a FSM?
FWIW, I had coolant in the middle of the block like that. That metal pipe (bypass tube) did not have enough FIPG at the water pump. I would take it off and reseal so you don't have an issue in the future. I still have the expensive ass FIPG that is for coolant....
Looks like that knock sensor harness is toast. Mine was too.
Yeah I was gonna check that out tomorrow.
And that harness was garbage, picked up a new one cuz the other one wasnt even worth trying to salvage
Took the heads in today. The guy let me hang out in the shop while he looked them over. Showed me alot of cool shit and taught me a few cool things.
Anyways while I was back there he found 3 cracks in my passenger head. So yeah, this repair just got a whole lot more expensive:suicide:
Found a pair of machined heads on CL for decent price, gonna go look tomorrow, they seem legit but I want to look them over quite a bit first.
All three cylinders have cracks like this
Taking over my dads garage im sure he appreciates it:rolleyes:
My truck sits nice without all that weight!
Discussion Starter #10
hahah glad I can help!
Yeah thats what it would seem like but I have been watching my temp gauge the whole time all paranoid. huh oh well.
Picked up the other heads today from a guy on CL for 300. Theyre in good shape so theyre gonna be bolted right in on Friday.
If only I didnt have to wait until Friday :aahg:
Discussion Starter #15
You know I thought it was a spark plug electrode too but it had a distinctive nail head on it. The only thing I can think of is it sat in a yard for a while and got in there some how? :confused:
Alright, time to pick your guy's knowledge.
So I picked up the used and very clean heads off the guy on craigslist. After doing my homework I confirmed my suspicions that I will have to check and most likely adjust the valves. The reason for this is that the heads I bought did not come with the shim buckets or valve pucks (whatever you wanna call them). So since I am going to be using the ones from my old heads I assume they will not be just right.
Now to my understanding after reading a few different threads on yotatech and some google searches, also talking with a few machine shops and the stealership; all I need to do to check the clearances is install the cams, turn them until the lobes are facing directly up and stick a feeler gauge under them. If the clearance is off I was told that taking the shims out of the pucks is simply done by prying them out with a knife or small screw driver? Sounds pretty easy but I have never done this type of valve adjustment and spending over $300 at the stealership is out of the question.
So school me on this one guys. I am going to attempt to do this tomorrow night. (YES I will post pics). I have all the shim buckets labeled and numbered so I wont just randomly be placing them around. And if I am correct the Exhaust Cam valves should be around .009 of an inch and the Intake Cam valves should be around .011 of an inch right??
Thanks a bunch I really hope to get my truck done this weekend, driving a Passat is nice for the speed but the ladies really dont seem interested :lmao:
NorCal Chapter Pres
I don't know about the clearance spec, but the process is correct. You can also remove the shims and buckets with a magnet.
It's VERY easy, just very time consuming.
Discussion Starter #17
Getting the whole bucket out is pretty easy with a magnet. Im just not sure on the process of getting the shim out of the bucket. It doesnt help that they arent infront or me.
I plan on it taking quite a long time but oh well, after this project I feel confident in every corner of my engine.
Hopefully my math skills arent too rusty
NorCal Chapter Pres
Want me to e-mail you the file for adjusting the shims?
Spec is:
Intake 0.13 – 0.23 mm (0.006 – 0.009 in.)
Exhaust 0.27 – 0.37 mm (0.011 – 0.014 in.)
I don't think you'll need an SST since you will just have to remove the camshaft
Cracked heads... damn bud, that sucks. But, shit, what can you do. At least you can do the labor yourself. A luxury that not everyone has.
Discussion Starter #20
Yeah exactly. Every time I bitch about the cost so far I just remind myself I could be paying Toyota to do this.
Phill: I sent ya a PM.
I realized last night once I complete this job on my truck the only thing I havent done is set up my own gears. Maybe my ring gear will fall apart soon and I can figure that out too:rolleyes:
1 - 20 of 37 Posts
