Has anyone have this problem? I have a 07 Trd sport the drivers side goes out all the time the longest was about 2 months. I just put a set in and lasted 4 day I'm not touching the bulb at all and tried hids and about every brand bulb. It's always the driver side if anyone can give me a ideas to try that will help lol thanks
Do you have any electical mods? Lights,dual batteries?
truck ~n~ tow
HO efficient bulbs tend to draw/require more current.
* OEM wiring is sub par for the newer HO type bulbs.
HO type bulbs are not generally a higher wattage...
just more efficient and requiring less resistance
Because of this... some bulbs will have a shortened life.
and the oem light harness can get warm from the resistance.
That resistance can be less then friendly to HO bulbs.
best way to eliminate any issue...
is by adding a performance headlight harness
that draws directly off the battery.
there are several mfgr's out there...
suvlights.com
danielsternlighting.com
some others I can't remember off hand.
It could be home brewed as well...
if ya know what yer doing.
I have the suv light harness...
I run HO 90/110 bulbs...
the bulbs are a recent install...
but the HO efficiency bulbs that were in there previous
were nearly 8 years old and still going.
Even with muh 90/110 watt bulbs...
the suv wiring harness does not get warm.
I recommend the upgrade...
even with standard oem bulbs...
the light harness will offer more light output (noticeable)
just due to it's better efficiency and lower resistance.
I was running the stocks from the dealer too. But I will look into that sounds good thanks for your help
