1 - 1 of 1 Posts
My heater fan has stopped working, I removed the fan and tested it, it works fine. I tested the ground and It was good, the 30 amp heater breaker fuse is good. When I turn to fan to low and high i can hear my relay clicking, which means the switch is probably working.. I swapped the relay with one from my parts truck to make sure it wasn't the relay. Needing to get it going to pass my inspection.. Any advice would be appreciated!
Thanks!
1 - 1 of 1 Posts
