hey guys I'm installing some hella supertones on my 86 4runner. I'm trying to retain the factory horn button, which completes the circuit by grounding. I found this diagram on google, just wondering if its safe to run it like this. The ground wire in the steering wheel seems pretty tiny to ground the relay. One of the stock horn wires is always hot, so im trying to figure out the best way to run the relay.
http://www.junkyardgenius.com/wiring/Images/HornWire.gif
thanks
just like that, but right off the battery
yeah definitely, I have an aftermarket fuse panel it will be wired to, i just feel the ground on the horn is too small to be sufficient for the relay...
Really? that would make sense though. Thanks! I'll let you know if it works, or if my truck burns to the ground. ha
