I am trying to adjust the height of the driver side and the collar is siezed. Yes I jacked up the truck, yes I loosened the set screw, and yes I tried peneratring lube. In the process of tryng to turn it, I also broke the spanner wrench. I cut off the flat end of a screw driver and tried using that but the screw driver is now bent.
However the passeger coil over moves pretty easily.
Any ideas?
SilverStreak05 said:
Get another spanner wrench and then use something on it that will give you some leverage, like a piece of pipe.
since I broke the spanner wrench using only my hands, wouldn't the wrench break even easier with using a pipe?
Banned
with it jacked up is the uniball cup hitting the spring? if so it sometimes makes it hard to turn the nut because the spring wants to also turn. i only ask because this was the issue with my we co's.
any pics?
