Anyone ever had to change out a differential seal? On my front diff, drivers side, where the axle goes into the diff, it is leaking like crazy. Some sort of seal is wasted I guess. The part is only like $12 and some clip is $1.20, and I have taken apart the front end almost that far before, but looking for any advice / help on this particular repair.
I guess there is a rubber seal or something in the diff casing once you pull the inner axle out of the diff (this is what I assume is toast). But a friend mentioned a spring of some sort?
Also, if I am losing diff oil, since I do not have amnual hubs, I assume everything is turning in there (this is bad I guess). Not sure how long I have before things get even worse as far as the diff.
Any help appreciated, I would have dealer do it, but I am already getting the clutch replaced at almost $600.
