I have a 4" procomp lift. I just redid the rear suspension. I got rid of the blocks, and to keep the same amount of lift, installed a set of 2" over Deaver springs and a set of 2" over Cornfed shackles, plus a set of mx-6 adjustable shocks...4" of lift.
Now here's the problem. The driver's side is sitting like an inch lower than the passengers. It looks horrible.
I read on customtacos.com that the driverside can sit lower because of the extra weight from the battery, steering and gastank on that side. But they said there's no known solution. That's surely not the case.
If all, or even some, of the lifted tacos out there were tilting like mine. I know I would've seen it addressed on the forums by now.
Please help. Between the procomp lift, deaver springs, and the rest of the work I have in her. I just can't accept defeat.
