I've got to drop my transmission to replace my Flexplate and I've run into a snag. I've already dropped the carrier on the rear drive shaft and seperated them. However, I can't seperate the front part of the rear shaft from the transfercase. It's like it's welded in place or something... Any tips?
Thanks,
99' 3.4 - 4x4
I use a big dead blow brass hammer; jars the thing loose with out destroying anything.
Thanks John. Unfortunately I don't have one of those in my tool arsenal. With the drive shaft bent at about 90 degrees, I used a rubber mallet to try to drive it off the propeller shaft of the tcase. I was afraid to hit hard because I didn't want to damage the shaft or U-Joints.
Where did you hit with the brass hammer?
If you hurt the u-joint with a hammer... it was time to replace it anyway.... or you have REALLY bad aim!
Just wack it!
Though mine isnt' STUCk on there like your's sounds. It goes take a hit or two from my hammer to knock it loose. Usually one hit (not swinging it much) with my 3lb sledge and holding the shaft at an angle from the t-case will pop it right off. Just like getting it off the diff.
Thanks. I will give that a shot in the morning. Also, I was reading through a Haynes manual and they mentioned marking the D-Shaft with a scribe or chalk to preserve the balance. How important is that? I didn't do this when I seperating the rear. Thanks,
JK
