4022.1
I did the prerunner to 4wd conversion.Everything I did was textbook according to the FSM all the way up until checking the fluid level at normal operating temps. Here are my problems: The truck doesn't move,when I shift into 4lo and have the shifter in neutral... it goes in, then I shift into D but the transfer case makes noise and the shifter vibrates like hell. When the shifter is in R,D,2 or L, 4lo grinds waaaaaay more than it should and doesn't even go in. Then I put the t-case shifter in 2hi and it doesn't even move in D or any other gear for that matter. Then when I try to put it in park ... it makes a slow grinding noise then it gets louder and finally stops. All the noise is coming from the rear of the tranny/t-case assembly. WTF??!?!?!?!?!?!?!? Is my transfer case bad? Or is the tranny bad? HELP!
thanks
Duc
562-743-5665
thanks
Duc
562-743-5665
