Bought a set of Hella 500s last night and they didn't come with the instructions to install them. I would like to hook them up to the high beams if I could. If anyone has a wiring diagram or instructions I would greatly appreciate it. I am going to tackle this tonight.
Thank you
Thank you
Here is a picture I found before but cant tell if this is wired to the hi-beams or not.
http://mikeegan.stormpages.com/HellaDiagram.gif
Also here is a thread about wiring to the hi beams via a relay. I don't think it is vehicle specific however:
http://www.the12volt.com/installbay/forum_posts.asp?TID=52891&get=last
I just installed some 550's on my truck yesterday. I believe that when you wire the kit, you splice the wire into the wire for the high beams and then connect it to number 85 on the relay. Then put the green wire to any wire that has a constant power supply and to the switch. I think that is the way to do it. I put my 550's on my bedbar, so I had to wire it different than that.
Here is the website if that doesn't help:
http://www.hella.com/produktion/HellaPortal/WebSite/Internet_usa/ProductsServices/PDF/Inst_450.pdf
