That just took me to some random post about moving to this forum, but I did search over there and found a couple things. I posted over here because I thought they had disabled the search function on the old forum.FlipSideUp said:I found a similar discussion on the old board:
http://forums.delphiforums.com/tacomaterritory/messages/?start=Start+Reading+>>
Its a 48''. I am thinking about mounting it on the bedrails right under the back windows and bracing it up somehow. I just havnt figured the bracing part out yet.Toyasaurus said:Depends on which length you have. You could put it up against the front wall or a tool box it you have one or under the rail on the side of the bed. I just ran bolts through the bottom of the bed and blot it to the bed floor. It holds it down well, just make sure that it is reinforced well to distribute the weight of the jack.
Do you think you could post up a pic of that for me.shuwtist said:I used the lock rac and mounted mine to the front of the bed. I used a couple pieces of 1" square stock to mount the locking end so it would be straight. Works great.
tacoma_trd1999 said:Opinions on where to attach the Hi-lift 4x4 RAC to the bed rails or another part of the truck that would give easy access.
No, but I did pay a fortune for it.00Andy said:Not to go OT, but did you make your own sliders?
