Hi all, hope you can help. I replaced my sealed beam headlights with headlight casings that allow for the use of H4 bulbs. Everything plugged and played perfect. Now i picked up a Set of Xenon HID headlight conversion and I'm trying to figure out which is positive negative and which is postive for the high beams. With the HID kit all i need to plug in is the pos to the lowbeam positive and negative in the socket. Can anybody help to by telling me what each of the 3 sockets in the stock harness are?
Thanks in advance, Rich
I cant tell you right off hand but they should be easy to test with a multimeter. So your hid kit has high and low beams? cool
Opps my bad...they are only "low beam" I meant to say I"m trying to figure out which of the 3 wires is for High beam so that I won't use that one..sorry for the confusion.
Ok i just went out and looked, the one thats flat not either of the two that are vertical, whether it be top or bottom is positive for the high beam. In other words, the top one.
Thanks for checking so quick...last question, do you know if the left vertical is low beam positive and the right is negative or visversa?
Thanks again for your help
Rich
