That's right, these spacers are priced at half-off on the webpage! Buy as many as you need, we machined over one thousand of this size last week. Thanks for your support! (We cannot extenend this offer to any other sizes, including different bolt sizes in 3/4")
3/4" - 5/8" High Misalignment Spacer HALF OFF
Purchase Here!
x 2.
~Miguel
" High Misalignment Spacers are used on rod-ends or spherical bearings to gain more pivoting angle than standard spacers. They also reduce the size of the hole to accommodate a smaller size bolt. We make every high misalignment spacer out of 4130 chromoly, race style spacers are heat treated 17-4 stainless."
http://www.kartek.com/products/all/heims/heims.htm
Discussion Starter · #7 ·
whats it do?
Austin
HMS video
Machined from 303 Stainless steel, these spacers will provide more degrees of misalignment in a rod end and lengthen the life of the joint while increasing performance. These spacers downsize the bore of the rodend to accomodate an extended radius of the ball. This feature allows the use of a more reasonable bolt size. Price is per piece, two pieces needed per rod end.
