1 - 18 of 18 Posts
yup... it got me this weekend. took off 13". i couldn't believe how easy the whole thing was to pull off. right now all i have left to do is finish up a little bit of welding on the inside seam when i get more argon/co2 and make/rework my rear bumper. I didnt even go through one whole 4.5" cutoff wheel and the seam was so tight i didnt need to do any grinding. the only thing i had to do was notch the lip under the tailgate for the frame rail to make both peices of the bed mate back together perfectly
i asked my friend to bring over his new 37's so i could test fit them on my truck. right now i'm running 32s but i fit 37s with room to spare on my rear axle... its really time to get cutting for the sas :saw:
Looks good! I found the project to be very easy as well. People who spend 19 hours trying to fit up the 2 halves shouldn't cut their shit with a sawzall :D 13" is the magic number to put a double cab shell on too, nice :)
You are going to cut those frame rails off aren't you??
yeah, i cut 2 inches off last night and tacked on that peice of 3x2 just so i had something for the drive to work today but i will be cutting the frame shorter and making a new rear bumper within the next couple days
Whew, after seeing that 2x3 I thought...What the crap!
didnt get far but got a start on the new bumper tonight
i'll be putting a trailer hitch and recovery points on the main bar which is being made from 3x2x1/4 and the wrap arounds are being made from 3x2x1/8. tomarrow i should have the wrap arounds welded and cleaned up
Discussion Starter #9
the rear bumper isn't completely done, but its pretty close. all i need to do is add support for the side wings, weld in the trailer hitch tube, and get some weld on shackle mounts. i got everything else pretty much finished up
next up is a sas to level the front and some 35"+ tires
Discussion Starter #11
no, i havent cut my overload leaf on the chevy springs yet so right now they pretty much stop just before they reach flat
hey, that exhaust out the side is pretty cool ;)
I am guessing all that trimming on the rear wheel well is in preparation for the 35s? Looks good though, no problems with the exhaust moving when heated up and cooled down?
Discussion Starter #16
yes, the fender trimming is in prep for bigger tires. i actually cut the rear when i still had my stock springs that sagged so much i couldnt clear 32's, but now i'll have plenty of room for some meats once i level the front. i'd like to maybe go all the way up to 37's if i can find a decent set
as for the exhaust, i have absolutly no problems with it moving around. i actually have the exhaust hangars welded to the frame so i doesnt vibrate or move around as much as it would if i had the rubber hangar mounts in there
1 - 18 of 18 Posts
