OK... maybe not for everyone...
but I hate throwing useable things in the trash...
Anyway... bought two li-po's
and they came packaged in a blister pack/card.
So... before throwing those into the trash...
thought I'd see what I could do to use them some more first.
The blister paks aren't scale looking by any means...
I only thought to cover the opening that runs thru
and under the flat bed surface. (looks funky to me)
just a couple expectations for me...
...attempt of PTM to the primary body (failed that)
...assure tires do not rub at full articulation
short of the slight paint mismatch... good enough
li-po blister pak similar to mine...
mounting is simply replacing the 6 deck screws (3 per side)
those secure that deck to the cage.
I replaced the original deck screws with similarly sized cap bolts and nuts.
Du-bro 2-56 X 1/2" Cat. No. 310, Nuts = Cat. No. 560
pics of it mounted...
as you can see I didn't spend a much time with it...
I think it looks awrite... maybe a little better with time spent...
but I really want a full std bed... this is just a temporary thang ;-)
so tell me how much you hate it !? :flipoff:
it's not rocket science...
so I see no point of pictures showing 6 bolts and nuts securing
hopefully common sense would overcome. Lol
