Tufemup said:
I know this is a really old thread but my horn doesn't work now and I read through all the horn related threads that came up under a title search for "horn". Fuse is good. Hazzards work - same fuse as horn. I can hear a clicking under the dash when I press on the steering wheel horn. I assume that is the relay. Does the clicking mean the relay is good or bad? Checked the wires to the horns themselves up front by the radiator and they look fine. Even sprayed some electrical cleaner on them to be sure the contacts were good. Someone mentioned the spiral wires in the steering wheel but I don't want to try to take apart the steering wheel cause it involves the air bag. Any more ideas besides aftermarket horns and sticking my head out the window and yelling?
Do you you have tilt steering and did you use the mechanism alot ?
Tilt the steering up and try again to see if it is any different at other positions... If it it gets better or worse... then it would be in that cable...
Could be the contact at the horn pad...
Though the clicking says the the relay is working... It could be that the relay is getting tired though... Especially if yer a constant horn user... LOL
But it's one of these three...
Spiral wires
Horn pad contact
Relay
A fourth idea is a loose contact at the fuse box... Though least likely
If you changed to an after market air horn or something... You might still have the same problem if trying to utilize the OEM horn pad...
Sounds to me like you'll need to pull the steering wheel horn pad/air bag junk...
