I could probably search through my FSMs for the answer, but I'm not in the mood and its easier to type.
For a while now, I was getting crappy antenna signal with my stereo. When I was removing my fender today, I found out why.
The Coaxial cable that runs from the cab (i assume directly from the back of the head unit) was torn out from the antenna. My guess is I will have to replace the entire antenna mount as well as the section of antenna wire.
Can I splice the cable or should I replace the whole section in its entirety?
Is there anyway to save the antenna? It looks like the cable was ripped out of the antenna base.
I really really really don't feel like tearing apart the dash for this one stupid wire.
TIA
Not sure on the Tacos, but my old 4runner had the cable go straight from the antenna to the head. I know you can buy little DIY coaxial connectors at radioshack, it may be easier if you have enough slack. How does it attach to the antenna mount?
TIA
Post or PM me a picture. I can figure out what you need, or least point you in the right direction. Coax can be spliced easily.... no worries. If radio shack doesnt have it, I probably do.
Here are the pics. I figured it could be spliced, just not sure how that would affect the radio antenna signal.
I still have to figure out how to reattach it to the antenna, and I have the feeling the Cable and Antenna are sold together as one assembly.
I'm pretty sure even if I can splice it, I doubt i'll be able to reattach it to the stock antenna. I just need to find some type of replacement.
Discussion Starter #5 (Edited)
Just found out it is all one unit.
Dammit.
Ordered one from partznet.com, Cost ~$37.00
I had something similar happen, so I yanked the whole thing and put in a new antenna. Universal-type, so i had to use it and parts of the old antenna to get it to mount properly. Was a serious PITA.
