1 - 3 of 3 Posts
a stock 3.0 for example is 150 hp at 3000 rpm and 180 ft lb of tourqe. how would i figure out what the tourqe is say in 4-lo with a transfer case having 2.57 gear ratio, or even better dual cases with 4.7s in the rear case. i know how to calculate crawl ratio but was curious if its possible to do the same with tourque?? Thanks
a stock 3.0 for example is 150 hp at 3000 rpm and 180 ft lb of tourqe. how would i figure out what the torque is say in 4-lo with a transfer case having 2.57 gear ratio, or even better dual cases with 4.7s in the rear case. i know how to calculate crawl ratio but was curious if its possible to do the same with tourque?? Thanks
2.57x 180; 4.7x180... hp remains the same.
compound low (duals) 2.57x4.7x180 ;)
1 - 3 of 3 Posts
